Is it possible, to integrate some new options on copy and move?
* I would like to skip all old files or in other words: only copy newer files, like midnight commander on linux do (Option "Update")
and
* Do not create empty dirs for junctions, but do nothing on it. That will be helpful for merging dirs, i.E. for tools like WinBuilder or other temporary backup directories like "c:\users\lexa" and "c:\users\lexa.bak"
EDIT:
* and, if possible, I would get a list.log at the end of a copy action with all files listet, which could not be copied because of errors in filenames, path too long, not readable. That makes possible to check these files and the reasons later - after all 383,031 files
Currently I have to cancel the operation and check 1-2-3 files I've written down and then I start copy again and wait for the next error.
Thanks and greetings, lexa
