Problem with keyboard shortcut on German keyboard
Posted: 03 May 2006, 15:54
by zxmar05
There is a problem with the 'My Documents' keyboard shortcut ( CTRL + ; ) on keyboards with german layout: it does not work.
Instead the 'Network Neighborhood' ( CTRL + , ) dialog appears.
The cause may be that ';' is on the same key with ',' in the german layout so that for 'My Documents' one has to press 'CTRL + SHIFT + ,'
Regards,
Eduard
Posted: 03 May 2006, 23:24
by th.
Try 'CTRL+ü' for 'My Documents', it works for me.
Thomas
Posted: 04 May 2006, 01:04
by SvA
Thank you for this hint. It will be a time saver for me.
Posted: 04 May 2006, 09:39
by KNUT
th. wrote:Try 'CTRL+ü' for 'My Documents', it works for me
Sehr schön - Danke! :P Thanks a lot!
Posted: 04 May 2006, 22:52
by Tomcat
As Eduard stated the shortcut on a German keyboard should be CTRL+(SHIFT+','), but this one seem to be predefined for the 'Network Neighbourhood'.
Per the documentation in http://www.altap.cz/salam_en/features/keyboard.html the NN should be brought up with Ctrl+',' but it also comes up with Ctrl+Shift+','. Can the latter one be redefined to bring up 'My Documents'?
Are other shortcuts known that do not work correctly on non-US keyboard layouts?
