2.5 RC1 has already expired
jackh
Post by jackh »
my 2.5 RC1 ("Expires on 01 November 2006") has already expired.
i tried a new download and install, but the problem remains.
jack
Mem
Post by Mem »
Sorry for stupid question - your system date and time si correctly set?
jackh
Post by jackh »
yes.
and i've solved it... mostly my fault. i would have replied a bit sooner but couldn't get back to the forum
the module update checker ran and told me that it had found new modules... the new beta, which was obviously wrong. at the same time, i ran a script that tried to run Salamander with a particular folder as the parameter... i have restricted Salamander to one window, so this should have updated my running Salamander. however, i had forgotten to update the script, so it was calling the old beta.
whew. anyway, it was the mixture of the update checker and my out-of-date script together that made me think Salamander had expired.
sorry for the fuss.
jack
Alwin-J.Mueller
New Version not correct???
Post by Alwin-J.Mueller »
Hello, CheckVersion giv me this URL
http://www.altap.cz/salam_en/newver.html
the newest Version is ss25rc1.exe, but it have only 26K, not 2M1! If i try to start installallation, i get a message like "~File isn't complete"
I have to try Download via FTP
ftp://ftp.altap.cz/pub/altap/salamand/ss25rc1.exe
But the ss25rc1.exe file have installed Salamander 2.5beta11 again.
And i'm get the epiry message at Salamander Start.
Anyway now i will try again, ss25rc1.exe have 2,2MB now, and not 2,18MB like ss25b11.exe. So i hope, this is the really newest Version!!
Re: New Version not correct???
Alwin-J.Mueller wrote:Hello, CheckVersion giv me this URL
This URL points to a web page, not a file to be installed. What did you actually download? Did you try to re-download it after you were informed that your file is not complete? Did you purge that file form your internet cache and from the cache of any proxy you are using before retrying?
Alwin-J.Mueller wrote:I have to try Download via FTP
Are you sure you installed that file you were downloading and that you subequently started the newly installed version? By default, Salamander installs side by side with older versions and does not automatically update/overwrite older versions.
Furthermore, if you have a value assigned to the default value of the registry path
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\salamand.exe
, your attempt to start Servant Salamander might be redirected to whatever is the content of that registry setting.
There is a bug in the Check Version plugin, we are working on solution.
Only one version of Servant Salamander 2.5 RC1 was released:
Standard version: ss25rc1.exe (2 303 384 bytes)
Full version: ss25rc1f.exe (5 007 268 bytes)
