Altar Salamander can`t connect across ISA-proxy
token
Post by token »
Hello!
I try to connect on FTP-server across ISA-proxy and get next error:
(17:39:39): 502 Proxy Error ( The specified Secure Sockets Layer (SSL) port is not allowed. Forefront TMG is not configured to allow SSL requests from this port. Most Web browsers use port 443 for SSL requests. )
Altar Salamander use adress and 8080 port for HTTP-type proxy and connect on 21 port to FTP-server.
For example Total Commander work OK with same options and type: HTTP with FTP support
I work with WinXP SP3
Please fix this for Altar Salamander 2.54
Thank You!
Re: Altar Salamander can`t connect across ISA-proxy
Either reconfigure TMG to allow port 8080 or reconfigure the proxy your FTP-connection uses to connect on port 443.
token
Post by token »
SvA wrote:Either reconfigure TMG to allow port 8080 or reconfigure the proxy your FTP-connection uses to connect on port 443.
I can`t reconfigure TMG - have not rights. And Total Commander build in FTP client work OK with use port 8080 for ISA-proxy server and same options! So problem in Altar Salamander FTP-plugin.
Thank you for this bug report.
AS 2.54 is frozen. We will release updates only for AS 3.x and further versions.
Anyone else have this problem?
token
Post by token »
Jan Rysavy wrote: AS 2.54 is frozen. We will release updates only for AS 3.x and further versions.
But AS 3.x as i know don`t support early Windows version. Maybe You can fix AS 2.54 FTP plugin only?
Thank You!
Do you still use Windows older than Windows 2000? We do not plan to support older Windows versions, it is too expensive.
