WinSCP separate threads
crystalidea
Post by crystalidea »
WinSCP hangs the whole file manager when the network is slow or inconsistent. Any way to add more threads to the communication?
crystalidea
Re: WinSCP separate threads
My whole salamander is now hanging for over 20 seconds because network is unstable and there's active upload
Meantime you can install WinSCP as separate program.
Works fine, and mostly it is newer version than plug-in in AS 3.0 beta 3 and have some advanced features too. :D
Just to clarify, you have background transfer's enabled and Salamander is hanging during directory listing?
