rjh extensions
pwarner
rjh extensions
Post by pwarner »
A number of years ago this little application appeared.
rjhExtensions v1.3
Copyright © 1999-2001 RjH Software
Description
rjhExtensions is a simple utility that will add a number of
useful functions to the context menu of Windows Explorer.
The utility consists of the extensions and an organizer that
allows you to control the placement of the extensions.
The program works flawlessly on 2.54, but on Beta 3 (X64) it doesn't work.
Re: rjh extensions
Welcome to the world of 64-bit software.
32-bit shell extensions don't work in 64-bit software.
pwarner
Re: rjh extensions
Post by pwarner »
ggrrhh, aarrgghh!
Thanks.
