filename.part1.rar
which contains
file01.txt
file02.txt
file10.txt
and
filename.part2.rar
with
file11.txt
file12.txt
file20.txt
When I open the first file then i can see files file01-10.txt - its ok but when I try to open (or unpack) the second one i still can see files file01-10.txt!
I've checked it in old 2.54 - the same issue
7-zip application opens it without any problems...
It's not multivolume - only small parts into very similar named rar files.
It's very annoying issue :/
UPDATE:
I think the problem is with dots in the file names.
There is a problem with title.part1.rar, title.part2.rar, but it work ok if files are named as part1.rar, part2.rar...
Anyway it looks to be a small but annoying issue
Best regards,
Wojtek
