Dropping files into AS PB103 x64 not working
Forum rules
Thunesier
Post by Thunesier »
In previous versions of Salamander, up to and includiung 3.0 beta 2, I used to be able to drop files into a folder, e.g. by dragging file attachments with the mouse from Outlook to Salamander. In beta 3 PB103 x64 that does not work anymore. :(
Re: Dropping files into AS PB103 x64 not working
What OS?
Are Outlook & Salamander running at different privilege levels?
Thunesier
Post by Thunesier »
Windows 8.
Correct. Salamander was running with admin privileges, Outlook not. When I change Salamander to run without admin privileges, dropping files into Salamander works.
Is this behaviour by design?
Yes, it is by Windows design.
We will implement the UAC support so you will not need to run Salamander as Administrator.
Andre.Ziegler
Post by Andre.Ziegler »
Thunesier wrote:Windows 8.
yes this is by design, this is how UAC works. read here about User Interface Privilege Isolation
UIPI prevents a lower privilege application from using Windows messages to send input from one process to a higher privilege process. Sending input from one process to another allows a process to inject input into another process without the user providing keyboard or mouse actions.
http://msdn.microsoft.com/en-us/library/bb530410.aspx
otherwise you can attack admin processes and execute bad code.
crystalidea
Post by crystalidea »
void EnableDragAndDropForElevatedProcess()
typedef BOOL (WINAPI *LPFN_CHANGEWINDOWMESSAGEFILTER) (UINT, DWORD);
#define MSGFLT_ADD 1
LPFN_CHANGEWINDOWMESSAGEFILTER fnChangeWindowMessageFilter =
(LPFN_CHANGEWINDOWMESSAGEFILTER)GetProcAddress(GetModuleHandle(TEXT("user32")),"ChangeWindowMessageFilter");
if (NULL != fnChangeWindowMessageFilter)
fnChangeWindowMessageFilter (WM_DROPFILES, MSGFLT_ADD);
fnChangeWindowMessageFilter (WM_COPYDATA, MSGFLT_ADD);
fnChangeWindowMessageFilter (0x0049, MSGFLT_ADD);
Doesn't look like solution for our problem: http://stackoverflow.com/questions/3794 ... pplication
crystalidea
Actually this function worked for me.
