Problems with Hot Paths
Posted: 30 Apr 2006, 12:47
by zxspectrum
If the directory name is a number for ex. "1",assigning hot path to that directory does not work.At least on my computers,it does not change to that directory,but to the root of the drive.Is this a bug? or i don't really know how to work with hot paths?
Please anyone check!!thx alot
Posted: 30 Apr 2006, 13:48
by Mem
It works for me with no problem (I've created directory "1" in root on FAT32 and NTFS partition).
Can you please check the value in your Configuration / Hot Paths and eventually past it here?
