Find duplicates and select duplicates
Posted: 01 Jul 2013, 00:01
Find duplicates is great feature to Find dialog, although I think it's a little buried in the menu and not that easily discoverable.
If I don't miss something obvious I would like to suggest a little enhancement to this action.
For example take a look at this result:
I had to select each duplicate by hand, which was very boring task, and generally if you are doing repetitive action with a computer, you are most probably doing something wrong.
I was also aware that I may accidentally double-click some item and launch all selected files by mistake.
What I want to suggest is a tick box in Find duplicates dialog, that will select all duplicate files and leave unique unselected, so that I can easily delete them.
But how to choose which is unique in a group of duplicate files? I don't have great answer, but using sort and selected all but first item would be acceptable in most cases I guess. (Or sort and select the newest/oldest)
Thanks
Thanks
