New Close All (Alt+Shift+F4) command?
Posted: 28 Apr 2013, 12:18
From http://forum.altap.cz/viewtopic.php?p=26343#p26343
Note: I have the same problem with other windows too (typically PictView or Internal Viewer). We should consider additional window menu command Close All (Alt+Shift+F4) that would close all windows of its kind (find windows, viewer windows, ...).Ether wrote:I sometimes end up with several used and unneeded Find windows
