Page 1 of 2
Branch View
Posted: 19 Dec 2005, 14:20
by -=Majkl=-
is there any function similar to totalcmd's Branch View? (CTRL+B). It shows all files in current directory and in subdirectories at once in one panel.
Thanks in advance
M.
Posted: 19 Dec 2005, 14:30
by cincura.net
If you think the Folders and Files tree, so this isn't currently implemented. But it's on Roadmap.
Re: Branch View
Posted: 19 Dec 2005, 14:40
by ino
-=Majkl=- wrote:Hi,
Thanks in advance
M.
I am using Ctrl+F instead without any comfort
so I wote for this function too!
Re: Branch View
Posted: 19 Dec 2005, 14:42
by -=Majkl=-
ino wrote:-=Majkl=- wrote:Hi,
Thanks in advance
M.
But you can't use all the functions normally available in panel, can you?
Re: Branch View
Posted: 19 Dec 2005, 14:50
by ino
No, I do not.
Can see only list with files...
That is why I vote for this feature!
Posted: 19 Dec 2005, 16:28
by .me
Branch View?
Is this the posibility to list all search results in a panel?
I only know such a feature from WindowsCommander (now TotalCommander)
If so, this would be really nice to have in SS.
Posted: 19 Dec 2005, 16:34
by cincura.net
.me wrote:Branch View?
No, for this time.
As I said, it's on Roadmap.
Posted: 19 Dec 2005, 17:02
by Gandolf
Branch View (Total Commander) or Flat View (Dopus), and also in other file managers, is a useful feature for looking at the contents of several sub-directories at the same time. Ctrl+F will do a similar function, but not in a very convenient display. I also vote for this feature to be added to Servant Salamander. I don't see it mentioned on the Roadmap, are we talking about two different features? Branch view is not the same as Tree view.
Posted: 20 Dec 2005, 06:01
by JohnFredC
Hoping for this function also.
I call it the "recurse subfolders" mode. Shows all files that match the filter criteria in the current folder and below. Great for feeding to the multi-rename tool.
Of course, should allow all customary file functions... delete, rename, copy, move, etc, plus all customary views... detail, thumbnails, etc.
Posted: 20 Dec 2005, 08:33
by bebe
Add my vote for this function, too
Re: Branch View
Posted: 20 Dec 2005, 08:51
by KNUT
-=Majkl=- wrote:[...]It shows all files in current directory and in subdirectories at once in one panel
Here're the results from Germany: 12 Points
This function is a very good idea!
Posted: 20 Dec 2005, 20:55
by omega
i created a small jpg for this idea. Anyone here wants to put it online? i don't have webspace. Let me know and i'll mail it to you.
I think this feature request is worth to build inside SS. Though i wouldn't want to use it on the C root since windows has lots of dirs and thousands of files.
Not to mention all files inside the program files dir.
Posted: 20 Dec 2005, 21:03
by cincura.net
If you want to place it on the web, mail me.
jiri (at) cincura (dot) net
Posted: 20 Dec 2005, 21:20
by omega
Thanks Jiri.
Someone posted this request in an earlier post with topic tree view.
He suggested it displaying all files in the 2nd panel. Like you guys i prefer displaying everything in 1 panel so you can still drag and drop using the 2nd panel.
Posted: 20 Dec 2005, 22:27
by cincura.net
Yeah. On 1st panel Tree View (or something like this) and on 2nd something else (i.e. normal view).
I vote too.
