Deletion of (hidden) files named "icon?" not possible
McYoda
Post by McYoda »
Hi there
I'm working with the latest Salamander beta. I get errors while trying to delete files (which seem to be sourced from an Apple computer) named "icon?".
Deleting them in Windows Explorer is no problem, though.
Regards
Martin
Re: Deletion of (hidden) files named "icon?" not possible
The problem is probably Unicode characters in the file name. Salamander does not support unicode yet. It has been discussed here a few times already.
Martin, there is Salamander function Shift+F3 - Open Active Folder in Windows Explorer. It is useful shortcut for such cases.
McYoda
Post by McYoda »
Thanks for the hint. This will definitely shortcut the deletion of such files.
There is nice new feature in Altap Salamander 3.0 beta 1: focused file or directory from Salamander panel is focused in Windows Explorer window when you press the Shift+F3.
