Viewer doesn't show text files correct
Posted: 27 Apr 2006, 21:39
by Eric
Some files are not shown correct in the viewer. All chars are shown in a vertical line.
Is this a codepage/coding problem?
Posted: 27 Apr 2006, 22:46
Could you please send us a screenshot?
Re: Viewer doesn't show text files correct
Posted: 28 Apr 2006, 10:34
by Tomas Kopal
Eric wrote:Some files are not shown correct in the viewer. All chars are shown in a vertical line.
Can you verify that the file is not Unicode encoded? (e.g. switch to hex-view and check if every letter is not followed by a zero).
Internal viewer does not support Unicode texts yet.
Posted: 28 Apr 2006, 13:47
by AbteriX
Yes, that looks like an unicode file.
Posted: 28 Apr 2006, 22:22
by Eric
Tomas Kopal wrote:Can you verify that the file is not Unicode encoded? (e.g. switch to hex-view and check if every letter is not followed by a zero).
It's an unicode file. Are there any plans to support Unicode? I thinks it's a important feature.
Thanks
Eric
Posted: 28 Apr 2006, 22:59
by jis
Eric wrote:It's an unicode file. Are there any plans to support Unicode? I thinks it's a important feature.
You are not alone.
1) Try to Search "unicode" - Search found 21 matches including your post.
2) Here is ALTAP Roadmap for next Servant Salamander versions:
http://www.altap.cz/salam_en/newver.html
- Unicode support, UTF-8,16,32 (names in panel, viewers, find, convert, compare).
Posted: 30 Apr 2006, 18:59
by Stefan
I use Lister32 from Mr. Ghisler for unicode files.
I have made a new *.reg entry in the viewer options (above of the *.*)
and assigne this to Lister.exe
I have also an new entry in the alternative viwer list as *.*
with Lister.exe.
You can reach this alternate viewer by pressing Ctrl+Shift+F3
So i have there view64.exe and ListXP.exe too.
You can do the same for Ctrl+Shift+F4
Alternate viewer for unicode-files
Posted: 01 May 2006, 20:50
by Klettermaxe
Stefan wrote:I use Lister32 from Mr. Ghisler for unicode files.
This is a very useful tip.
Lister32 nearly looks like the internal viewer and is integrated very well in Servant Salamander. I use it on first place in my list of alternate viewers so I can reach it easily with ALT+F3.
