PictView background color cyan gets yellow
Posted: 28 Feb 2013, 00:09
by mdruiter
I would like to report a minor issue with the PictView plugin.
Sometimes I save PNG files with only 256 colors, with transparency. When I view those with PictView, the transparent background shows as
yellow, although I have the background color(s) set to
cyan. This confused me.
For convenience I attached an example image:
- Example image
- t-shirt 2013 mini 2.png (11.53 KiB) Viewed 10429 times
I tested this with the version 3.0 beta and the issue is still there.
Re: PictView background color cyan gets yellow
Posted: 11 Apr 2013, 11:46
by Kris
I can imagine that you also get the same result with Windows Photo viewer, it is because of the RBG colours in your display profile.
You can read about it here:
http://support.microsoft.com/kb/939395
Regards,
Kris
Posted: 12 Apr 2013, 22:07
by mdruiter
Kris wrote:I can imagine that you also get the same result with Windows Photo viewer, it is because of the RBG colours in your display profile.
Well no.
First, in Salamander, it's not a Vista-only thing. It also happens in Windows 7 and XP. The issue you mention is Vista specific.
Second, every viewer I use displays the transparant background as white or transparent (white and gray blocks). I tried that now on Windows XP, using Microsoft Photo Editor, QuickTime PictureViewer, Paint, Internet Explorer, Adobe Photoshop and Windows picture and fax viewer.
As I'm using XP now, I cannot try the suggested solution, but I don't expect it to work.
Can anyone confirm my issue
Posted: 14 Apr 2013, 23:03
by Ether
I tried several colors. White, black, some gray, green and yellow show okay. I can confirm at least three colors that show differently (in the attached picture). I use Salamander v2.54 on Windows 8x64 Pro.
