Combine ZIP files created by PKZIP for multiple diskettes
Posted: 21 Apr 2006, 22:08
by Blue Hornet
I have a ZIP file formerly created by PKZIP (in 1996) to span two diskettes. Unfortunately, I no longer have diskette drives, so I would like to combine the two pieces of the ZIP file into one file on my hard drive which I can then UNZIP normally.
I tried the Split and Combine plugin to attempt this, but that didn't work. Any other suggestions, please?
Thank you.
Posted: 22 Apr 2006, 13:22
by omega
Ofcos this plugin doesn't work for you. Google for pkzip, get the tool to combine your files
Posted: 24 Apr 2006, 14:24
by Lukas Cerman
No problem, it should work with Servant Salamander. There are two ways to do it:
(1) either rename files to
archive.z01, archive.z02, ... , archive.z(n-1), archive.zip
and enter the last part of the archive,
(2) or rename the last part of the archive to *.zip and enter it. While upacking dialog windows will popup to let you select another parts of the archive.
Lukas
