Quick search doesn't work for '!' (Shift+1)
Guest
Automatic file focusing doesn't work when you start to type it's name and it contains '!'. Amazingly it does work on czech keybord which I don't use at all... so it's not worthy... And on english keybord shift + 1 doesn't focus exclamation character.
Open Servant Salamander configuration: Options > Configuration > Panels and clear the Use Shift+number for go to Hot Path option.
Use the Ctrl+number to open Hot Path (instead of Shift+number).
http://www.altap.cz/salam_en/features/k ... navigation
