Confirmation dialog on doube-click multiple selected files
Posted: 17 Dec 2012, 22:58
by otrov
I did this terrible scenario couple of times. Last time being just now, while trying to move ~30 PDF files, and thought to suggest addition to "Confirmations" configuration dialog.
Perhaps, make it off by default but allow user preference of double checking this potentially catastrophic behavior.
It's not that uncommon double click to be triggered on accident, and if I could choose I would tick it on.
Re: Confirmation dialog on doube-click multiple selected fil
Posted: 18 Dec 2012, 10:47
by mdruiter
Was this in the
Find Files list? I
reported this as a problem before.
Posted: 18 Dec 2012, 13:55
by otrov
Yes it was.
So this looks like a bug or misfortune design of find dialog, as I can't make to launch bunch of selected files just by double clicking elsewhere, including Explorer and Explorer's search mode
PS. IIRC that is how Nautilus file manager behaves on Linux - allows launching multiple selected files. I can't make use of it, without confirmation dialog guarding from accidental double-clicking.
Posted: 09 Jan 2013, 10:42
by Petr Solin
I have fixed this behavior in Find dialog. In new version, double click and Enter key open focused file or directory (not all selected ones as in Explorer). You can still use Open command from right click context menu to open all selected files if you need it. And you cannot open focused file or directory by double clicking in empty space, you must double click on file or directory. Right click context menu newly opens only when clicking on selected files and directories (not also when clicking in white space like in Explorer).
