Missing Send To Items
Posted: 24 Nov 2012, 07:50
by ddn2003
I'm currently using Altap Salamander 2.54 on Windows 7 64-bit SP1. When I right-click and open the Send To menu, I am missing 2 items from the list. Is there anyway to fix this?
The left list is from Windows Explorer. The right is from Altap Salamander.
Notice the 1st 2 items on the left list are missing from the right list.
Any help is appreciated
Re: Missing Send To Items
Posted: 24 Nov 2012, 09:27
The problem is that you are running a 64 bit OS and AS 2.54 is a 32 bit application. The context menu is created by shell extensions, which in your case are 64 bit, thus not displayed in Salamander.
This matter has been discussed many times here. Just search for the terms shell extension
Posted: 25 Nov 2012, 16:39
You can try 64-bit version of Altap Salamander 3.0: http://www.altap.cz/salamander/downloads/eap/
