Although my Windows 7 machine seeks the network perfectly, Salamander, for some reason, suddenly does not.
Clicking on "Network" causes the app to just hang, it never finds the network.
I can map to specific network drives, but the app simply isn't detecting or discovering the network all of a sudden.
Salamander works perfectly with XP SP3, but not Windows 7.
Salamander 2.54 does not see my Win 7 network
Re: Salamander 2.54 does not see my Win 7 network
This is weird. Browsing the network shouldn't hang Salamander. It seems like something went wrong with the Network plugin. Can you try backing up your configuration, wiping it from the registry, uninstalling and re-installing Salamander and see what if it helps?
