GZ File Decompression
Posted: 07 Sep 2012, 10:54
by jcgriff2
Hi -
,gz files are not decompressing fully; no error messages.
GZ files are ~45 MB
Uncompressed ~400 MB
I'm getting partial un-GZ files ~ 15 MB with PB87.
I am able to un-GZ the files with other 3rd party apps, but don't like that option.
Thank you. . .
John
Re: GZ File Decompression
Posted: 07 Sep 2012, 12:58
by Slanec
I think that the devs won't really be able to help without any additional information about the file (any special attributes, characteristics, the tool the file was created with, or the file itself).
Posted: 07 Sep 2012, 13:13
Hi John, Are you able to provide us such GZ sample?
Posted: 12 Sep 2012, 07:09
by jcgriff2
Hi Jan. . .
I will be glad to provide access to the GZ files; however the info is of a sensative nature.
I'll send the info to you privately.
My apologies, as I know doing so defeats the purpose of public forums, but no alternative in this case.
Regards. . .
John
Posted: 12 Sep 2012, 09:17
Not a problem, thank you. We will keep your files private and destroy it.
Posted: 30 Oct 2012, 14:06
by Tomas Kopal
Thank you for your help, the problem should be fixed in next Salamander version. Please re-test and let us know.
