Start minimized and close to tray?
Skipper
Post by Skipper »
Hello,
I'm searching for two settings. The first one will start the Salamander minimized and the second is an 'Close to tray' function. Is there something like that?
Greets, Skipper
Re: Start minimized and close to tray?
There is no Salamander command line option to do so.
Though you can do that either with the desktop shortcut (Shortcut | Run: Minimized [dropdown]), or from a command line:
START  /MIN  salamand.exe
> Close to tray
Should be able to find (all escaping me at the moment) a general "close to tray" utility to handle it.
Tray It! looks to work (on Win7 too).
Or this, RBTray. No UI. Just run, then right-click on the 'minimize' button. Then left-click on the tray icon to restore, or right-click on the tray icon for a very brief context menu.
