Search Function
Salamander01
Search Function
Post by Salamander01 »
Hello,
I want to look after same file name and file maintenance.
Is that possible in the salamander 2:53?
Re: Search Function
Alt+F7 (Find) | Ctrl+D (Command, Find Duplicate Files...), is that what you are looking for?
Salamander01
Re: Search Function
Hello,
No that's wrong. I would like to search for file names and file contents. Is a file name or file content with the search word is they are displayed.
Re: Search Function
Could you re-phrase the question, or provide some example of what are you trying to achieve? Annotated pictures (screenshots maybe) would probably help.
xm
Re: Search Function
Post by xm »
I guess that he would like to find not only all the files with some search phrase within but also all the files named after the same search phrase, e.g. while searching for all the files containing "abrakadabra.txt" string he likes to also reveal all the files named "abrakadabra.txt"
