Empty console window
Posted: 23 Mar 2006, 13:26
When I lunch a Windows application from the Command Line toolbar, starting it with ALT-ENTER I get an empty console window, which stays there until the Windows application ends. I can close it manually without any adverse consequences.
Is it possible to get rid of this window by default?
My Environment:
WinXP SP2
Salamander settings which I thought might be relevant:
- 'Close shell window after command execution (in Command Line)' not selected
- 'Open Files through salopen.exe' not selected
Changing these does not change the misbehaviour.
I use the standard cmd.exe as the console shell (denoted by %COMSPEC%)
I did not modify AUTOEXEC.NT or CONFIG.NT
AUTOEXEC.BAT and CONFIG.SYS do exist in the root, but are both 0 bytes in size.
My Environment:
WinXP SP2
