Drive button bars
Scot
Drive button bars
Post by Scot »
I'm a long time Windows/Total Commander user. I'm very used to having a drive button bar above each panel- click the drive and you're there.
Is this an option in Salamander?
How about / and .. directory change buttons?
If they are there, I can't find them.
Thanks-
Scot
Scot
/ and .. dir change
Post by Scot »
Disregard / and .. request- found them.
Use the Options > Customize > Left (Right) Panel Toolbar command for Parent/Root directory button.
