AS 3.0 PB75 - Network copy speed test
Forum rules
We would like to ask you for comparing AS 2.54 / AS 3.0 PB75 / Windows Explorer network copy speed.
Copy the same large file over your network (wired or wireless) and take Task Manager screenshot as we did in http://forum.altap.cz/viewtopic.php?t=5447
We have report (Czech only) about slowdown introduced in AS 3.0 PB75: http://forum.altap.cz/viewtopic.php?f=16&t=5493
How does AS 3.0 PB75 work on your network? Please let us know...
Re: AS 3.0 PB75 - Network copy speed test
1,01GB file over 100Mb/s local network, Win7CZ
1. AS 3.00x64, Avg. speed 10,60 MB/s
2. AS 2.54, Avg.speed 3,05 MB/s
3. WE, Avg.speed 11.10 MB/s
Edit: copying from my Notebook to Win2008 server. I will test the oposite direction later...
- Clipbrd3.png (6.89 KiB) Viewed 118730 times
Are those data from upload or download? Could you test the opposite way as well. I have encouraged problems while downloading file from remote to local drive in the Czech post.MartinS wrote:1,01GB file over 100Mb/s local network, Win7CZ
And now opposite direction from Win2008 server to notebookMartinS wrote:1,01GB file over 100Mb/s local network, Win7CZ
1. AS 3.00x64, Avg. speed 11,0 MB/s
2. AS 2.54, Avg.speed 10,1 MB/s
3. WE, Avg.speed 11.3 MB/s
- Clipbrd2.png (5.77 KiB) Viewed 118660 times
Test in 100Mbit LAN at work. Test in Gigabit LAN at home will follow ...
Writing speed to network seems to be O.K. But strangely older Salamander is faster in reading from network than the public beta
- network.png (6.49 KiB) Viewed 118393 times
Re: AS 3.0 PB87 - Network copy speed test
Test System: Windows 8 Professional x64 Bit / AS 3.0 PB87 / 1 GBit Lan
Slow copy speed of a file with Salamander.
Meanwhile I have tested some more other file manager. None of them had shown this problem with the low copy speed.
Could you solve the problem?
I have no more hope, because I started an thread with the same problem in December 2011 here (http://forum.altap.cz/viewtopic.php?f=2&t=5252) and nothing happened
Ran across this - FWIW; 15 Free File Copy Tools Tested for the Fastest Transfer Speeds.
(No I'm not promoting anything or any method, but just look at the [often quite] varying results obtained by all these products promoting, in the broadest sense, "speed".)
Thanks, interesting test! We will patch our copy routine to use more simultaneous transfers at one time to get better network performance, so we may try to compare it with some of these tools.
Faster asynchronous algorithm is implemented from Altap Salamander 3.0 beta 3 (PB103).
Please test it across your networks and let us know in a new thread if you find any problems. Thank you.
