Is there a way to run 3.0 x64 without the stress test mode being on? I use both Actual Windows and Beyond Compare so I can't do much with the x64 version since any right-clicks crashes things. I understand it's issues with those other programs but it would be nice to run the EAP 3.0 x64 anyway to see how it runs otherwise.
Thanks!
Bob
Turn off Stress Test mode?
Forum rules
Re: Turn off Stress Test mode?
Right now there is not such switch, it is hard-coded in the Salamander start-up sequence.
Please "vote" by contacting both developers so the issue has higher priority.
