				AS 3.0 (PB75 x86) - hangs in XP SP3 x86
				Posted: 05 Apr 2012, 12:33
				by wsorg
				AS 3.0 (PB75 x86) hangs when using or opening some plugins such as PictView, Eroiica and others. Please pay attention to these key problems.
Operating system: Windows XP SP3 Pro.
				Re: AS 3.0 (PB75 x86)
				Posted: 05 Apr 2012, 13:05
				Thank you for your bug report! Could you reproduce the problem?
I tried several RAR archives and I'm unable to crash AS 3.0 PB75.
				Posted: 05 Apr 2012, 13:32
				by wsorg
				Jan Rysavy wrote:Thank you for your bug report! Could you reproduce the problem?
This problem occurs when opening a password-protected rar archives with encrypted file names...
				Posted: 05 Apr 2012, 13:34
				by Andre.Ziegler
				wsorg wrote:This problem occurs when opening a password-protected rar archives...
I have the same issue:
http://forum.altap.cz/viewtopic.php?f=24&t=5472
				Posted: 05 Apr 2012, 14:15
				by stepand76
				PictView plugin works for me.
				Posted: 05 Apr 2012, 14:27
				by Eva Eden
				CheckVersion plugin from AS 2.54 doesn't recognise new Salamander version. All filters (release, beta, preview build) are checked. Are this solved in 3.0?
Thx, Eva~
				Posted: 05 Apr 2012, 21:42
				Eva Eden wrote:CheckVersion plugin from AS 2.54 doesn't recognise new Salamander version. All filters (release, beta, preview build) are checked. Are this solved in 3.0?
Thx, Eva~
We will push CheckVer notification for the next EAP version. There are
several issues in PB75 we want to fix.
				Re: AS 3.0 (PB75 x86) - hangs in XP SP3 x86
				Posted: 06 Apr 2012, 09:55
				Fixed
