Editors & Viewers
Posted: 16 Mar 2006, 12:34
by ADB
With the 2.5 beta 11, I have to manually configure a lot of file extensions for the viewer to work with. For example, *.DOC, *.TXT, *.INI...
A problem that I never had in the past with precedingt version of Salamander. It is very annoying.
Is it due to a misconfiguration/installation, or a new politics?
Thks
ADB
adupinbe@noos.fr)
Re: Editors & Viewers
Posted: 16 Mar 2006, 12:49
by jis
ADB wrote:With the 2.5 beta 11, I have to manually configure a lot of file extensions for the viewer to work with. For example, *.DOC, *.TXT, *.INI...
Thks
ADB
adupinbe@noos.fr)
Probably due to a misconfiguration/installation.
Try these threads:
Uninstalling older versions
FTP settings lost
Editors & Viewers
Posted: 16 Mar 2006, 12:59
by ADB
OK, everything fine now.
I had to uninstall beta 10 and beta 11, then reinstall beta 11.
Seems there is a more complete list of extensions now.
Thks
ADB
Posted: 16 Mar 2006, 13:03
by KNUT
I never had these problemes. All old configurations are active in the newest beta!
Posted: 16 Mar 2006, 13:26
by jis
ADB wrote:OK, everything fine now.
Thks
ADB
With this procedure you have done so called clean installation. You lost your previous settings, but you lost your previous mis-settings too
And this cure your problems.
Posted: 16 Mar 2006, 14:01
There is a problem:
-Operations with Windows Registry are terribly slow under Windows XP.
-Windows XP kills not-responding processes during OS shutdown.
-Servant Salamander is not responding during "Saving configuration" stage.
Result: configuration is corrupted.
Solution: Close all running applications before you shut down Windows.
We know about this issue and will try to fix it (at least indicate it).
Posted: 16 Mar 2006, 15:16
by KNUT
Jan Rysavy wrote:-Operations with Windows Registry are terribly slow under Windows XP.
@Altap-Team: Does that mean, the next beta will have an option to save configuration in a ini-file
(using an ini-file already mentioned by Jan Rysavy in
this and in
this thread)
Posted: 16 Mar 2006, 17:02
KNUT wrote:@Altap-Team: Does that mean, the next beta will have an option to save configuration in a ini-file
this and in
this thread)
No. We must finish the language translation support, I'm sorry...
