Compare with word wrap
Eva Eden
Post by Eva Eden »
Dear Altap team,
your comparing tool do a very good job! But it would be more comfortable with word wrap !!!
For files with longer lines I've to start extern comparing tools (Beyond compare, Araxis merge, Winmerge). This shouldn't be!
Also, do you think about more features: copy to left, copy to right, better optical overview in folder compare (with subfolders)?
This would be great!!! Thx in advance!
Eva Eden~ <°)))><
Re: Compare with word wrap
White not "wrap", do note that you can switch from a vertical to a horizontal view (Ctrl+H) which may help in some situations.
But yes, if you're dealing with some very long lines, wrapping would be nice.
