Altap Questions
Posted: 31 Oct 2011, 04:44
by SuperShark
Hi, I like Altap Salamander. My personal opinion is that it's the best, if not the best Windows Explorer Alternative. Although I have a few questions:
- I want to preview EXR / HDR / PIC in the explorer view, how can I ?
- I want to turn favorites into Tabs ?
- How can I remove the line that is around everything as seen in this image ?
- I created a User Menu how come it's gone after restarting Altap ? Can I add a keyboard short-cut to User Menu programs ?
Re: Altap Questions
Posted: 31 Oct 2011, 16:33
by therube
If you have turned off, Options | Configuration | General -> Save configuration on exit,
then you must specifically save the configuration, Options | Save Configuration,
before exiting, or else settings such as User Menu changes will not be saved.
Re: Altap Questions
Posted: 31 Oct 2011, 21:10
by Ether
SuperShark wrote:- I want to preview EXR / HDR / PIC in the explorer view, how can I ?
By 'explorer view', you mean thumbnail view? If so, you probably want to ask for support of these formats in the PictView plugin (and you should make a separate topic for that). Also, you can try the Explorer Thumbnails plugin (assuming you can see the thumbnails in Explorer).
SuperShark wrote:- I want to turn favorites into Tabs ?
This is not currently possible. Support for tabs is on the roadmap, but right now other improvements are in development.
SuperShark wrote:- How can I remove the line that is around everything as seen in this image ?
You can change the color to white in Options > Configuration... > Colors > Item: Frame around thumbnail in panel.
Re: Altap Questions
Posted: 03 Nov 2011, 04:46
by SuperShark
I added a program to the user menu, but only the program title appears then it stops.
Re: Altap Questions
Posted: 03 Nov 2011, 11:36
by Ether
What was the program? What exactly does "it stops" mean? If it was a console application, it's normal for it to show up and disappear instantly.
Re: Altap Questions
Posted: 04 Nov 2011, 01:07
by SuperShark
Ether wrote:rogram? What exactly does "it stops" mean? If it was a console application, it's normal for it to show up and disappear instantly.
It's not a console application. It's a regular executable Windows program, the splash screen loads then stops.
Re: Altap Questions
Posted: 05 Nov 2011, 03:24
by therube
And ... it's name?
Re: Altap Questions
Posted: 05 Nov 2011, 04:59
by SuperShark
Microsoft Rich Copy
Re: Altap Questions
Posted: 05 Nov 2011, 05:21
by therube
Re: Altap Questions
Posted: 05 Nov 2011, 05:28
by SuperShark
It won't load in the User Menu ? Pretty nifty program. I haven't used it that much, I keep it around.
