				Unpacking archive - pre-fill name
				Posted: 13 Mar 2006, 09:11
				by cincura.net
if you use Alt-F6 for unpacking archive, it would by usefull to pre-fill the path into the field according to filename without extension.
I'm unpacking the whole archive into the directory often and this will be little bit faster for doing - Alt-F6, Enter, done.
				Posted: 13 Mar 2006, 09:19
				Moderator: not a bug, moved to the Feature Requests section.
Look at Options > Configuration > Archivers > Unpack to subdirectory named by archive.
				Posted: 13 Mar 2006, 09:22
				by cincura.net
				Nice! I've never seen this option.
Thanks.
				Posted: 13 Mar 2006, 09:48
				Posted: 13 Mar 2006, 09:57
				by cincura.net
				Yes, I know it, but not using it. Not helpful for me.
				Posted: 13 Mar 2006, 15:44
				by KNUT
				Jan Rysavy wrote:Look at Options > Configuration > Archivers > Unpack to subdirectory named by archive.
Ha ha
 really good - never noticed this one in the configuration
				Posted: 31 Mar 2006, 10:48
				by AbteriX
				Jan Rysavy wrote:Moderator: ...
I am just need this option too.
Normally i have an seperate zipper installed.
Since i carry SS on my USB-Stick with me and come to pcs without an zipper installed ,
i want to use SS to unpack zips in an new folder called like the zip archive.
With this option it works like a charm.
Thank you for this feature.
				Posted: 23 May 2006, 17:25
				by schroeder
would it be possible to also offer this option (Unpack to subdirectory named by archive) in the Unpack dialog itself instead of the Configuration settings?
Sometimes this naming scheme is very handy but sometimes I dont want the extra folder to be created.
schroeder
				Posted: 23 May 2006, 17:46
				by SvA
				I suggest you activate the option and press DEL before ENTER if you don't want the subdir (Empty field = current dir). (Never tried 'Unpack to other pannel' option, so this might not work when it is activated.)
				Posted: 23 May 2006, 17:57
				by schroeder
				SvA wrote:I suggest you activate the option and press DEL before ENTER if you don't want the subdir (Empty field = current dir). (Never tried 'Unpack to other pannel' option, so this might not work when it is activated.)
 The simple things in life...danke schön für den Tip.
				Posted: 23 May 2006, 18:42
				by schroeder
Well...sounded nicer than it actually is. Using this method you basically disable another nice feature: Unpack to other panel (without explicitly checking the option) and by just pressing the DOWN arrow (as mentioned by Jan here:
http://forum.altap.cz/viewtopic.php?p=921#921).
You can erase the name and unzip it to the same folder, but you cant erase the name and just unzip it to the other panel. That's where a checkbox option in the unzip dialog comes in handy.
schroeder
				Posted: 23 May 2006, 22:41
				by SvA
				schroeder wrote:Well...sounded nicer than it actually is. Using this method you basically disable another nice feature: Unpack to other panel
Yes, of course you are right. I did not intend to give this as the solution to all needs.
For me, using this setup let's me access the the four possible cases in descending order of effort (the most frequently used with ENTER; the second frequently used with DEL, ENTER ...).
On the other hand, you can see from this that a single switch does not cover all user's needs. There are four possible cases:
1) Zip file directory
2) subfolder named according to zip file in current directory
3) other pannel
4) subfolder named according to zip file in other pannel
(my precedence is 2, 1, 4, 3)
A user should be allowed to choose his favorite as default and any of the other cases on the fly.
				Posted: 23 May 2006, 23:53
				by schroeder
				SvA wrote:A user should be allowed to choose his favorite as default and any of the other cases on the fly.
I dont disagree. But anyway, I think that an option to change the settings in the actual unzip dialog would be nice.
schroeder
