SS & Renamer-Plugin Enhancements
I really like the renamer-plugin but I miss one feature:
If I select two or more folders I can rename all files inside these folders by using the counter. But I can't cofigure the renamer so that the counter in every folder starts from 1 or whatever I choose.
my renamer settings:
$(Counter:1,1,d,3,0).jpg and [X] include subdirectories
now the renamer works this way:
[DIR1]
[DIR2]
I wish I could use something like this:
to recieve this:
[DIR1]
[DIR2]
the other thing is that if I select more then one file and press [F2] in SS, the renamer plugin should start.
[DIR1]
[DIR2]
to recieve this:
[DIR1]
[DIR2]
							(o.O) -(@.@)- (/o.O\) ,,,`Q´,,, {~.~} (^.^)
						Re: SS & Renamer-Plugin Enhancements
yes this is good idea.me wrote:if I select more then one file and press [F2] in SS, the renamer plugin should start.
				Guest
Only if one of the selected files has focus. If focus is outside the selected files (which it normally is having selected a block with Space or Ins) then I would want to rename the focused file and NOT the selected files. Anyway, is it that much more difficult to press Ctrl+Shift+R than F2?.me wrote:if I select more then one file and press [F2] in SS, the renamer plugin should start.
Definitely not, but pressing [F2] would be much more comfortable.Anonymous wrote:Anyway, is it that much more difficult to press Ctrl+Shift+R than F2?
Have you ever select 2 or more files and then renamed only the focused?
I guess not.
Btw.
I use the renamer-plugin very often and so I changed the hotkey to Ctrl+Shift+A because this combination seems to be better for me as a non-perfect-10fingers-writer.
F2 on selected files for Batch Rename..me wrote:if I select more then one file and press [F2] in SS, the renamer plugin should start
F3 on directory for Calculate Directory Size.
etc.
Such "optimizations" will lead to more complicated user interface. Imagine the menu items, toolbar buttons, bottom toolbar items, documentation, beginning users. Plugins are optional components which can, but don't have to be installed and Batch Renamer is a plugin.
We don't think this is a good idea.
				Lukas Cerman
Thanks for suggestion, it is an interesting idea. I add it on my todo..me wrote:I really like the renamer-plugin but I miss one feature:
okay I found the ideal key for this task (I never thought this could work): [NUM ON/OFF] on the numeric blockJan Rysavy wrote: F2 on selected files for Batch Rename.
etc.
@Lukas Cerman: thanks - even if this feature will never be implemented the renamer is great.
(for .me the main reason for buying this software)
						Threat highjacking
Hi Lukas,
thank you for your graet plugin.
I use the mass renamer often to wrote the commands from hand.
So it would be nice to have shortcuts for the placeholders like
$(O) for $(OriginalName)
$(N) for $(Name) and $(N:0,2) $(NamePart)
$(E) for $(ExtPart)
$(D) for $(Drive)
$(P) for $(Path)
$(R) for $(RelativePath)
$(U) for UNC path
$(S) for $(Size)
$(HH:mm:ss) for $(Time:HH:mm:ss)
$(dd.MM.yyyy) for $(Date:dd.MM.yyyy)
$(C:1,2) for $(Counter)
and
L for lower
U for upper
M for mixed
S for sentence => $(NU: ,1)$(NL:2, )
so
$(NL) would be $(Name:lower)
and
$(NU:0,3 ) would be the same as $(Name:upper,0,3)
and
$(RL)-$(NU) would be relative path in lower and name in upper case
and as improvement would be nice
$(NM) - $(NS).$(EU) {read as NameMixed, blank minus blank, NameSentence, DOT, ExtensionUpper}
with Regex
would rename
mad monday - I LOVE YOU TO MUCH.mp3
to
Mad Monday - I love you to much.MP3
							Hi Lukas,
$(E) for $(ExtPart)
$(D) for $(Drive)
$(P) for $(Path)
$(U) for UNC path
$(S) for $(Size)
and
L for lower
U for upper
M for mixed
so
and
and
with Regex
would rename
to
Stefan
Pleased user since v1.52 - Licence# 0306-0046-01
				Seelenquell
another request:
i rename many files in different directories. can there be an option in the plugin-menu to select the last "renamer"-process?
like:
Batch Rename.. (key-combination)
last option (key combination)
now i select the files, go in the plugin menu, select last plugin, select batch rename, go to pulldown, get last configuration
then i could go to plugin -> renamer -> last option
everything could be faster and less complicated.. ya know what i mean?
like:
				cincura.net
				Seelenquell
				Lukas Cerman
Hi Stefan,Stefan wrote:Threat highjacking
Hi Lukas,
the abbreviations seems to be interesting. But this would be feature for geeks only.
What about implementing some kind of autocompletition? You write a first letter or few more a and press TAB key. It could work like autocomplete in unix shell. By pressing TAB key you rotate through possible strings having the same prefix.
It would be context sensitive -- offering only strings that are valid on the place.
Pressing TAB outside parenthesised expression would work like an ordinary TAB -- moving you to the next form in the window. After the unclosed parenthesis, it would work for the autopletition. There is a strong assumption that you would like to finish the expression first (by the closing parenthesis) and then move to the next form.
Thank you for your interest, Lukas.Lukas Cerman wrote:Hi Stefan,Stefan wrote:Threat highjacking
Hi Lukas,
Sorry but I favor the abbreviations.
I think the expression would be cleaner to read.
$(N)-Backup_0601.$(E)
instead of $(Name)-Backup_0601.$(ExtPart)
And no extra key to press.
> for geeks only
I don't think so, i know a few tools how use [N]-[C,1,2].[E]
This [xx] syntax is btw more comfortable for me
on an german keyboard layout than $(N).
That extra $-key incommodes me. Is it worth to discuse this?
And Lukas, can you implement that case thing like $(NU) and $(NL) ?
$(NU,0,1)$(NL,1,-0).$(EU) instead of
$(Name:upper,0,1)$(Name:lower,1,-0).$(ExtPart:upper)
And will this work with regex too as i ask in my last post above.
Or maybe an extra feature like $("any char or sign") for to stop on this "any char" ?
$(NM)$(" - ")$(NU,0,1)$(NL,1,-0).$(EU)
read as mixed case till find space,minus,space and then sentence case and upper extension.
Thank you for your help.
Stefan
