req: WIM Support
req: WIM Support
req: WIM Support (with 7-zip)
7-zip supports Windows Imaging Format (WIM) files, but 7-zip plugin does not.
Re: req: WIM Support
As I was thinking about it, I'd like to have integrated all of the formats supported by 7-zip application (namely NSIS).
