PDF thumbnails don't show anymore
otrov
Post by otrov »
False alarm, sorry: http://forum.altap.cz/viewtopic.php?f=1 ... 096#p22096
I don't know if PDF thumbnails are handled by explorer thumbnail plugin which I have installed or by AS itself, but today I noticed that I can't see thumbnails for my PDFs in AS
I opened explorer and everything seems fine there. Problem could be that I've installed IE9, but that's wild guess
Does anyone have same issue? Is it possible to solve?
Thanks
[edit] It's also same for DjVu files. I have DjVu shell extension from caminova, but it also stopped to show inside AS
Re: PDF thumbnails don't show anymore
Have you disabled the Eroiica plugin?
otrov
Post by otrov »
I don't have Eroiica plugin - I didn't installed it
Now I think I posted in wrong forum, as I'm almost sure problem is with explorer thumbnail plugin and IE9
Can someone confirm this behavior, and if possible, moderator to move this to explorer thumbnail plugin thread?
Thanks
SelfMan wrote:Have you disabled the Eroiica plugin?
Eroiica plugin works fine.
otrov wrote:Now I think I posted in wrong forum, as I'm almost sure problem is with explorer thumbnail plugin and IE9
I can partially confirm - I've got IE9 and I've disabled Eroiica plugin and my PDF thumbnails are blank. I don't have a system without IE9 at the moment, so I can't confirm IE9 really is the culprit.
otrov wrote:moderator to move this to explorer thumbnail plugin thread?
Just post a link to this topic with a short explanation there.
Explorer Thumbnails on the left, Eroiica on the right.
klonuo
Post by klonuo »
Hello,
I have similar problem, which is perhaps slightly different, because I use XP SP3 32b
As you can see, Salamander shows these ugly icons instead thumbs (for PDF extracted first page, and for FLAC thumb - associated icon)
PDF are associated with Adobe Acrobat 7, and FLAC with foobar2000
Also I use explorer_thumb plugin and don't use Eroiica, as I found it performance regarding PDF thumbs extraction slow, then without caching, resulting in undesired behaviour for my low end P4 with 1GB RAM
Does someone know if this can be resolved by some setting in Exlorer of Salamader?
TIA
What are your settings in Options > Configuration > Drives ?
Any "use simple icons" checked? Are the affected files on a network drive?
klonuo
Post by klonuo »
"Use simple icons" isn't checked for any drive
This are local hard drives
Then it is possible, that your IconCache.db is corrupted. Locate the file in %userprofile%\AppData\Local (if on Win7) or C:\Documents and Settings\Your User Name\Local Settings\Application Data\Iconcache.db, rename it and reboot. Check if tyhe issue persists.
Before you can rename the file, you have to kill the explorer.exe process.
[edit]
There is a small freeware utility from Camtech 2000 - RefreshEm, which does the same.
klonuo
Post by klonuo »
Thanks for your suggestions
I'm running XP SP3
I've tried rebuilding icon cache (with Tweak UI) before I thought to post my problem here. Perhaps something else is wrong. I even reinstalled Acrobat 7, just in case, but without results in Salamander.
Other thumbs like AVI files, or others with custom shell extensions, like DjVu, are showing fine in Salamander, the same as in Explorer. But the ones I want most - PDF thumbs - simply don't want to show. I have large collection, and fast visual tracking is desired in many cases.
I've noticed also this strange behavior. For example consider this screen-shot:
Now, if I select "Tiles" view in right panel, PDF icons in "Thumbs" view (in left panel) also changes:
And just in current Salamander session. After restarting everything is like it was.
Just for clearance, I don't want to see associated PDF icons in thumbs view, but only thought to mention strange to me behavior.
Please verify the followin registry keys:
[HKEY_CURRENT_USER\Control Panel\desktop\WindowMetrics]
"Shell Icon BPP"="16"
"Shell Icon Size"="32"
[HKEY_CLASSES_ROOT\regfile\shell]
@="edit"
Twek UI likes to mess up the registry sometimes...
[edit]
Check also AS Options > Configuration > Viewers and Editors > "*.ppt;*.pct;*.pict;*.plt;*.prt;*.pdf;*.ps;*.eps;*.rdl;*.ris"
Is it associated with Eroiica Viewer (plugin) ?
Try:
Change to Internet Explorer Viewer (plugin)
OR
Temporary remove the .pdf extension from the list of assitiated extension.
Save AS configuration and restart te program. See whats happening.
klonuo
Post by klonuo »
SelfMan wrote:[HKEY_CURRENT_USER\Control Panel\desktop\WindowMetrics]
both are present
SelfMan wrote: [HKEY_CLASSES_ROOT\regfile\shell]
@="edit"
entry "reg:\HKEY_CLASSES_ROOT\regfile\shell\edit" is present, if that's what you meant
there is no "@" value with "edit" value data, but I created one then restarted Salamander with no effect
SelfMan wrote: Check also AS Options > Configuration > Viewers and Editors > "*.ppt;*.pct;*.pict;*.plt;*.prt;*.pdf;*.ps;*.eps;*.rdl;*.ris"
No, I disabled Eroiica because plugin is slower then Adobe shell extension and does not cache data, so I have to wait long time for my larger folders to show their thumbs. I could use Eroiica, but I'm trying Salamander as I found it performance and features like nothing else, and it seems petty if it's outperformed by Explorer for some feature I use often. Above all, I guess "Explorer thumbs" plugin does that job for Salamander.
I had PDF associated with external viewer - SumatraPDF. I removed viewer association, restarted Salamander, and unfortunately it's same.
Thanks for your time, maybe it's some other registry setting, but as I showed earlier in Explorer everything is fine
Then check if the explorer thumbnail plugin is property installed and enabled.
Try one more thing tho, create a new dummy user account and check what happens there when you log in as a different user.
Other than that, at the moment I have no further ideas what would cause this.
