Any tips for integrating your development/maintenance schedule with Altap?
Posted: 17 Mar 2026, 13:12
by Orik
Hi everyone, I use Salamander pretty much all day long to manage my log files and maintenance scripts, but I’m running into a scheduling issue. I tend to get lost in my folders and often lose track of time, which means I miss meetings because my work calendar is on a Google account separate from my personal one.
Has anyone found a way to automatically sync two Google Calendars? The idea is that as soon as I have something scheduled on one, it blocks that time slot on the other by simply displaying “busy,” so I can see my actual availability at a glance without having to check everything manually. If you have a little tool or a trick that runs in the background to bridge the two without it being a huge hassle, that would really help me make sure I don’t miss my upcoming team meetings. Thanks in advance!
Re: Any tips for integrating your development/maintenance schedule with Altap?
Posted: 24 Mar 2026, 10:04
by Orik
Hi again, just wanted to add a quick follow-up in case anyone else is struggling with this too. I did a bit more digging and came across a tool that seems to handle calendar synchronisation ((LINK REMOVED)) pretty smoothly. It basically keeps two Google Calendars in sync so that any new event marked “busy” on one calendar automatically blocks that time on the other.
I haven’t tested every feature yet, but it looks promising for anyone like me who tends to forget to manually update their availability. Hopefully this saves some headaches for anyone juggling multiple accounts!
