Crazy new version
ejor
Crazy new version
Post by ejor »
https://github.com/RedSalamanders/RedSalamander/
I love Salamander I'd used it for many many year bought it in the past several time :D
I could not thanks enough their creators for this tools I'm using everyday
As other I was sad the open source version did not have more traction, even if in the last weeks there is wonderful work from 0xeb to modernize it
So I decide to start something new and crazy, rewrite everything in modern C++ and modern dependencies on Windows
You could find in the GitHub and alpha version
If you are crazy enough to try it, any feedback is welcome
the doc is there https://github.com/RedSalamanders/RedSa ... /main/Docs
you could have:
- theming
- long path support
- Unicode support
- FTP/SFTP/SCP/S3/IMAP support
- view picture and Raw picture
of course still a lost of feature missing and a lot of polish needed, don't have to high expectation yet 8)
Re: Crazy new version
Wow!
The year 2026 will see the return of Altap Salamander to life! :D
I would like one main branch to enhance the functionality of the existing stable 4.0 (5+) version.
Now we have 3 forks at least:
- Open Salamander 5 (official, main/base reposity): https://github.com/OpenSalamander/salamander
- Open Salamander 5, now (renamed today to) Sally: https://github.com/0xeb/sally/releases/latest
- Open Salamander: Samandarin - https://github.com/KRtkovo-eu-AI/salamander/releases
- RedSalamander: https://github.com/RedSalamanders/RedSalamander
Thanks to the developers.
I'll just note that Red does not run on Windows 7.
RedSalamander.exe - Entry Point Not Found
The procedure entry point GetDpiForSystem could not be located in the dynamic link library USER32.dll.
Wonder if a mod can create a sticky post with that information?
You know, I could pin it, but wouldn't it be actually more awesome if you ACTIVE devs would cooperate and work on one fork together? That would be so much more efficient.
ejor
Post by ejor »
Yes, RedSalamander is built for Windows 11. It relies heavily on DirectX and modern Windows APIs.
If you need something that runs on Windows 7, OpenSalamander or another fork is the better choice.
To answer @SelfMan: I’m more than happy to accept contributions and collaboration on RedSalamander.
There are two different paths here:
* The legacy path, focused on broad compatibility and proven solutions refined over years of development and use.
* My current path, which targets the latest Windows versions and integrates new capabilities, accepting reduced backward compatibility where necessary.
I am for moving on. These days running on old OSs is dangerous. There are too many vulnerabilities.
ejor
Post by ejor »
long time no see but work progressing
New version there, still unicode and long path everywhere
Rewrite most of the UI to remove Win32, now mainly DirectX native
Fix a lot and add functionnalities
updated the doc:
a bunch of file system :
- 7z: Archives Open supported archives as virtual folders, usually by pressing Enter on an archive from file:
- ftp: FTP Browse/read/write/delete through the curl-based remote file-system plugin; server capability and credentials may limit operations.
- sftp: SFTP SSH file transfer with password or key-based authentication via settings or Connection Manager.
- scp: SCP SSH copy access; directory operations depend on server SFTP support.
- imap: IMAP mailboxes Browse mailbox hierarchy and expose messages as .eml files; deleting an .eml deletes the message when allowed.
- onedrive: OneDrive Personal Browser sign-in, browse/read/write/rename/move/delete, and directory size.
- s3: S3 object storage Browse buckets/prefixes, open/download objects, upload, overwrite, delete objects, and bridge-copy with compatible file systems.
- s3table: S3 Table Browse table buckets, namespaces, and generated *.table.json documents; read-only.
another bunch of viewer:
- viewer-text — Text/Hex viewer
- viewer-imgraw — Images + camera RAW
- viewer-space — “occupied space” treemap for folders
- viewer-pe — Portable Executable (EXE/DLL/SYS) viewer
- viewer-sqlite — SQLite table/query viewer
- viewer-vlc — media playback using VLC (requires VLC installation)
- viewer-web / builtin/viewer-json / builtin/viewer-markdown — WebView2-based viewers (requires WebView2 runtime)
the last version is there
https://github.com/RedSalamanders/RedSa ... ag/v7.0.14
As always any comments or idea is welcome
here or directly in Github
Hello @ejor,
fine job indeed. :D
