The Synchronize option is greyed out for the winscp plug-in menu
jumboryder
Hello. I am trying to synchronize folders on a server using Salamander. I loaded the 32-bit version. I see the WinSCP plug-in but the "Synchronize" and "Keep Remote Directory Up To Date" options are greyed out. How can I activate them?
Re: The Synchronize option is greyed out for the winscp plug-in menu
The synchronization options in Altap Salamander are only activated after a connection is established with the server.
You must first open the remote directory in one of the panels, until then, the plugin keeps these functions disabled as it has nothing to compare the local files against. If the connection is active but the buttons are still greyed out, check your WinSCP session settings to ensure that the selected protocol supports these operations.
Lukáš
Hardware & Software on globy.com
