Is anyone working the Open Source for Salamander?
lew
Post by lew »
I continue to use the final release version 4.0 to this day. I was just wondering if there is anyone taking it further.
Also, I have a drive that shows blue text for directory listing. Does anyone know what that means?
Lew
Brett
Re: Is anyone working the Open Source for Salamander?
Post by Brett »
Blue text indicates that compression has been activated for the relevant folder/files.
lew wrote: 06 May 2025, 16:16 I continue to use the final release version 4.0 to this day. I was just wondering if there is anyone taking it further.
Lew
You can check it out on github - https://github.com/OpenSalamander/salamander
ejor
Post by ejor »
Progressing well on a completly new rewritten version in C++ and directX
Unicode support and theme
I hope will be public beginning next year
https://imgur.com/a/OHxX3lv
