Cannot disable "Save configuration on exit"
wlathan
Post by wlathan »
I am using Windows 11 Pro 64bit and Salamander 4.0 (x64). I would like my Salamander configuration to show a common display every time it comes up. I found the Options > Configuration > Save configuration on exit. I can uncheck this option. However, when I restart Salamander, it comes up again with the latest configuration. And going to the option again shows that the option is now checked again. Any fix for this, or am I doing something wrong?
Thanks,
Bill
-=Majkl=-
Re: Cannot disable "Save configuration on exit"
Post by -=Majkl=- »
Yes, you are :) Because this configuration change has not been saved when Salamander exited, exactly as you wished. So, after unchecking this option, you need to save the configuration manually by clicking Options > Save Configuration
