Cant rename,delete or overwrite a file located inside a gzip / cpio archive.
ziomario
Post by ziomario »
Hello to everyone.
I would like to remove and or overwrite some files that are located inside a "initrd.gz" file (linux ramdisk image). I would like to add inside the archive 3 files that have the same name but they are different pictures. I've opened the archive with altap salamander and I have tried to copy and paste and to drag and drop the new files saved inside a folder in one of my disks inside the archive. Unfortunately it is not writable. The files don't stick inside of it. I don't know why and I would like to know if I can do this using some kind of workaround. I've attached an image to explain better that I'm trying to say.
2022-10-21 21 43 26.png (69.17 KiB) Viewed 74953 times
Re: Cant rename,delete or overwrite a file located inside a gzip / cpio archive.
The TAR plugin, which handles .gz cannot create archives and therefore also not modify them.
I recommend you modify the archive with some other tool. My choice was 7-Zip on Windows and tar on a Unix-like system.
I do not know, however, how an initrd.gz is structured within, and what restrictions apply. You should always be able to extract your archive to a folder tree, modify it there and use the recommended Unix tools to rebuild it.
