Convert all filesnames to UTF-8?
Jorgensen
Post by Jorgensen »
Hi
I need to upload a lot of files via FTP, and I wonder if it's possible to use Servant Salamander or a plugin to change to filenames to UTF-8?
Like this
Udbudsbrev åhaven.pdf -> Udbudsbrev Ã¥haven.pdf
Or does anyone know of a tool that can help with it?
Regards
bo
Re: Convert all filesnames to UTF-8?
My first thought was Everything, but then I thought... "just how", & I wasn't quite sure?
Second thought was Bulk Rename Utility, & since superuser kind of concurs, Convert File Names into UTF (& @ BRU, Character Translations How-To).
Beware of gotchas (just some links):
My filenames became unreadable after uploading the files via FTP. What can I do?
Character Set Conversion
Filename encoding and interoperability problems
I suggest avoiding UTF8 characters in file names and use pure ascii. You will avoid many "strange problems".
