Altap unable to load thumbnails for .JPG files
280
Post by 280 »
the issue does not happen with normal (lowercase) .jpg images, only with uppercase JPG, and I cannot seem to find a way to reload thumbnails after switching the extensions to lowercase (eventually just resorted to removing and putting them back)
Re: Altap unable to load thumbnails for .JPG files
I'm thinking it's going to be the particular files themselves, rather then the case of the extension.
Can you post a link to a few of the particular files.
Also, take some "lower case" .jpg & (copy) & rename to .JPG & confirm that those ("upper case") do still show the expected thumbnails.
