TAR plugin update
vilo
TAR plugin update
Post by vilo »
Hi all, I'm sharing a small update of the TAR plugin. I've added support for .xz and .zst archive types. Thanks to Altap staff for help.
See the attachment, download the plugin for your Salamander version, and copy the plugin binary into plugins\tar directory where your Slamander is installed, for example:
C:\Program Files\Altap Salamander\plugins\tar
Its configuration is not updated automatically, you have to go to the plugin manager, remove the TAR plugin and add it again, and then save configuration (Options/Save Configuration).
Hopefully it will be useful for somebody. If you find any problem, let me know.
And, of course, marry xmas :D
tar-plugin-3.08.zip
(267.38 KiB) Downloaded 4451 times
tar-plugin-4.0.zip
(267.35 KiB) Downloaded 5726 times
Re: TAR plugin update
Thanks for this great update, I often wished these compression formats were supported.
After installing the plugin (and saving configuration) I noticed an issue with Salamander. When I start it, it shows me a warning window with "Error Loading Configuration" and "(234) More data is available.". It seems to be related to the configuration stored in "HKCU\SOFTWARE\Altap\Altap Salamander 4.0\Packers & Unpackers\Custom Unpackers\13\Ext", specifically the extensions supported by this new plugin. I haven't tested it thoroughly yet, but it seems its length of 588 is too much for some preallocated buffer and Salamander isn't ready to expand the buffer and re-read the value.
Another report:
I tried to open a .deb file, but the plugin seems to get stuck trying to load the archive (I waited for 5 minutes or so).
This is the file: https://launchpad.net/ubuntu/+source/gn ... -1_all.deb
vilo
Post by vilo »
Thanks for testing and reporting issues. I'll try to fix them and will post here the updated plugin...
vilo
Post by vilo »
I fixed a few issues with the TAR plugin, I updated the attached archives in the initial post, so you can download it there.
As I can't change the plugin version (otherwise the lang modules will not work), make sure you have the binary from 7.1.2022.
Enjoy :)
.deb seems to be fixed. Thanks.
Not sure about "More data" yet.
Thank you for updating the tar plugin. I'm using xz time to time at AS 4.0. I have confirmed that it works for me. Took a xz file and compared the output when unpacked it two different ways and using AS.
vilo
Post by vilo »
I added support also for extracting bzip3 archives (.bz3 files), see my comment on github, there are also binaries for Salamander 4.
Enjoy :)
