Inside the working folder of customized "Salamander".
gregzeng
Post by gregzeng »
Salamander shows the details:
Size: 49.9 MB (52,422,387 bytes)
Size on Disk: 42.6 MB (44,691,456 bytes)
Contains: 316 Files, 202 Folders
This folder has backups of the settings, and shortcut links that are mirrored to other parts of the user system. The multi-language files are removed, so that English-only is retained.
When using the inbuilt 7z compression, the above is quickly made into one file:
27.4 MB (28,802,823 bytes)
If using Peazip in the 7z compression, just a little slower, on the ULTRA compression, the details are:
27.0 MB (28,406,191 bytes)
The hardware used was a Dell Inspiron 2n1 notebook, i7, 16 gb DDR4, 4 TB M2 SSD on the motherboard. Operating system is default Windows 10 Pro, version 19041 191206 1406, with all drivers updated.
Retired (1985) Chief Information Officer, Australian Capital Territory.
Re: Inside the working folder of customized "Salamander".
And what is the point of this post?
