Missing folder context menu "Open in new window"
pstein
Post by pstein »
When I right click on a certain folder in Altap I miss a context menu "Open in new window" which opens the corresponding directory in a new, second Altap window.
How can I enable this context menu?
Peter
Re: Missing folder context menu "Open in new window"
Salamander does not have this functionality, but you can use the user menu to emulate this function.
pstein
Post by pstein »
How do I setup a corresponding user menu?
Options > Configuration > User menu
Inser new menu item and name it (F2).
Command: $(SalDir)\salamand.exe
Argumenst:-R "$(FullPath)\$(Name)"
Initial directory: $(FullPath)
[_] Execute through shell
This will start a new Salamander instance with the current or selected directory opened in a the right pane.
Don't forget to store the configuration.
Salamander command line parameters:
https://www.altap.cz/salamander/help/sa ... ask_param/
