Copy file to multiple folders
mattwheeler66
Post by mattwheeler66 »
Is it possible to copy a single file to a multiple folder selection with Salamander? Thanks!
Re: Copy file to multiple folders
Sorry no.
As selfman wrote it is not possible via the "ordinary" copy function (F5).
This would be perfect example usage for Automation plugin. You would select multliple items (directories, files) you want to copy and then you would get a dialog where you would select or write multiple destinations where to copy. That should not be that hard.
