Problems viewing a csv file (F3) version 4.0 (x64)
keebellah
Post by keebellah »
It happens once in a while that Altp Salamader crashes when trying to view a text file, in this case it was a vsc file
Compressing and sending report automatically did not work so lets hope I can get it to you this way.
The Salamader reports are too large to attach so I've attach the file causing the problem
SB ORDERS.csv
(1.34 KiB) Downloaded 1038 times
Hans
"IT" Always crosses your path...
jsm
Re: Problems viewing a csv file (F3) version 4.0 (x64)
Post by jsm »
Probably the same issue as discussed here viewtopic.php?p=68092. There is a patch available.
