What is Support end date for Salamander v2.0
Satya2vvv
Post by Satya2vvv »
Using V2.0. Would like to know what is the support end date and component end for this version...
Re: What is Support end date for Salamander v2.0
Why would you use The pretty old version 2.0? It isnt supported anymore. the latest version is the 4.0 and if you need to run it on older systems, 3.8 is the way to go.
