automate - unpack multiple (protected) archives
midowbuj
Post by midowbuj »
hello, i am new here. I am facing the following 'problem'.
I use the unpack multiple achives plugin. This plugin i run against a folder which consists of many subfolders and each subfolder has one or more archives in it. The problem i am facing is that all these archives are password protected (encrypted - i know the password).
So when running the plugin it keeps asking me for the password. But i have to enter my password each time he passes a new archive. In my case i would have to type my password more then 1000000 times for all my archives to be unpacked.
I use 7-Zip as unpacker.
Is there a way to pass my password to the script so i do not have to enter every time my password?
Many thanks, Jurgen
Re: automate - unpack multiple (protected) archives
Do you use the same password for every archive?
If so, you could set up a new unpacker that includes the password as one of its parameters.
7z.exe  -pxxx  "%*"
(Or whatever the case may be.)
